massey for pulling
Tom
04-01-2004 07:55:16
Does anybody have any experience with massey 44's for pulling, any input is appreciated.
Slo
04-01-2004 18:33:26
 Re: massey for pulling in reply to Tom , 04-01-2004 07:55:16
Pulled a stock 44 in div 2, won the points championship in 4500 and came in 3rd in 5500. Still had the fenders, pto, and hydraulics on it. Had the hitch as close in and as high as legal, a good set of 15.5x38 F&R's on the back. It usually ran a bit light in the front in 4500, but since I still used the tractor for things other than pulling, I never lightened it up in the rear to get movable weight.
Usually pulled in classes of 15+, with several 70+ hp tractors in them, and did respectable for a low power tractor.
marlowe
04-01-2004 13:09:03
i pull a 44 special in 6000 and 7000 and 99.9% of the time in the top three on dirt. and top two on black top NO engine work but good tires 14.9x38 for dirt 15.5x38 black top. get the set up right and she will pull
JDBert
04-01-2004 10:28:31
Tom, I've got a 44' few engine mods running new 13.6x38's all traction field and roads. I only pulled it about 4 times last year and haven't quite got the tractor, tire pressures and weights figured out yet. But it seems like a strong tractor, the bigest problem I had was that 1st gear popped out, so I had to rig up a lock in for it.
buickanddeere
04-01-2004 08:41:19
A lightweight Massey 44 rowcrop with a few off the shelf parts in the engine and 15.5x38 Firestones are tough to beat in the 4500lb class.
