heavy allis
jeff
04-01-2004 06:27:25
I have a 1935 ac wc unstyled and it is striped for 3000 class and it is hevyier than most wcs why? another guy has a 37 with starter battery
cast front and rear and is lighter i have all i can do to get it at 3000 with minimal front weight
any thoughts would be great thanks jeff
L Hud
04-01-2004 13:47:05
 Re: heavy allis in reply to jeff, 04-01-2004 06:27:25
Check the front pedestal. It might have a late model out of a 45 which is heavier. The lightest pedestals are in late model WC and early WD's. Hope this helps.
Jeff
04-02-2004 04:32:20
 Re: Re: heavy allis in reply to L Hud, 04-01-2004 13:47:05
thanks for all the info ill check the pedestal
i just thought maybe the casting of that year was bigger or somthing i pull stone boat with it my club just went from 20 to 30 inch chain so the weight we pull will drop thanks again any other info would help thanks again
Wild Horses
04-01-2004 08:14:38
A buddy put an RC rear end on his WC. Claimed it was lighter. It got into 3250 without much else done. That's as light as we go around here.
Frank
04-02-2004 02:20:29
 Re: Re: heavy allis in reply to Wild Horses, 04-01-2004 08:14:38
Be careful with the RC rearend, the pinion shaft doesn't have the bearing at the end like the WC and if you put good power to it it will break off.
