JD 404 upgrade for 4020
wags
04-01-2004 06:17:03
has anyone built up the 404 and what parts would interchange, ie. 466 crank ect. and how many cubes can I get without a lot of machining?
naturally aspirated: would I be better to convert to gas or leave as diesel.
G-MAN
04-01-2004 10:58:49
 Re: JD 404 upgrade for 4020 in reply to wags, 04-01-2004 06:17:03
The 466 crank won't gain you anything, as the 404 already has the same stroke as the 466. In fact, the same crank part number was used in some of each, so there's no real strength advantage to a 466 crank, either. The 466 has a larger bore.
