What gear to pull in?
Farmallkid
03-31-2004 15:39:25
This is the first time ive bin on this forum so i thought id check it out. I want to pull this summer with my 52 M, I was wondering what gear to pull in? I will have 2 wieights on each side. 145lbs each no fluid in tires. thanks for any help.
Mopower
04-01-2004 04:09:23
 Re: What gear to pull in? in reply to Farmallkid, 03-31-2004 15:39:25
I started pulling a stock MM U at a few local pulls. 1st gear was all she could do with that tired old motor in 5500 pound class. But I learned that in a dead weight type class I could win a lot. A stone boat is the fun way to go for old stock tractors. A smart puller can beat a powerful puller.
colekicker
03-31-2004 18:04:38
Just remember, you want to get all that horsepower to the track. Before you worry about the gear, run her in 1st and get her balanced. That will make a bigger difference than the gear when it comes down to inches.
Dave
03-31-2004 17:13:51
If you have never tractor pulled before, if your tractor is bone stock, you will want to be in "farm stock" or division 1 classes, which are 1st gear only classes. You don't have enough HP to pull any gear higher. If there are classes that allow higher gears, you won't have a chance against these tractors, but try it once anyway and get it out of your system! Good luck, remember safty first, and have fun!
Farmallkid
03-31-2004 17:36:48
 Re: Re: What gear to pull in? in reply to Dave, 03-31-2004 17:13:51
Its just a pull at the annual steam show, so its for fun and bragging rights, you know the old red green show off. Thanks for the info.
Young Gun
03-31-2004 16:04:11
If you're not worried about going fast and want to be somewhat competitive, I would pull in 1st.
