cam clearance/stroker crank
Flyin Farmall
03-30-2004 17:07:09
What is the best way to grind a cam to clear the crank?Put it on a lathe,and cut down?or maybe just cut flats where there is interference?It is on a Farmall M.Thanx for the opinions!
TimC
03-30-2004 17:56:46
 Re: cam clearance/stroker crank in reply to Flyin Farmall, 03-30-2004 17:07:09
You also have the option of removing material from what ever is going to hit the cam. If its the big end of the rod then cap screws can can be used to allow more clearance. Go with the flats. IMHO you might save some time by doing the first one the hard way then copy for all the rest. You just need to index the cam x degrees past or before the intake or exhaust lobe keeping in mind which lobe is which and direction of rotation. The problem with grinding outside the block is one mistake is to many.
farmall
03-30-2004 17:22:34
Flats work the best. Its leaves more material so makes the cam stronger. For bigger strokes the flats need to be aroung .437 thick. This would be to weak if it were round. Hope this helps
Gump
03-30-2004 17:12:16
how much you gotta go? if not much, it would probably be easier turn in a lathe. if alot, I would go flats.
Gump
Flyin Farmall
03-30-2004 18:06:03
 Re: Re: cam clearance/stroker crank in reply to Gump, 03-30-2004 17:12:16
It dosen't look like too much,But I would hate to get it to thin.Do you know if Rick sent out my gear yet?
Gump
03-30-2004 18:11:22
 Re: Re: Re: cam clearance/stroker crank in reply to Flyin Farmall, 03-30-2004 18:06:03
I am not sure, probably better call and ask him. The M gonna be ready for he pull in April?
Flyin Farmall
03-30-2004 18:36:26
 Re: Re: Re: Re: cam clearance/stroker crank in reply to Gump, 03-30-2004 18:11:22
It is looking good!!I just have to finish this engine,and everything should be golden!Are you coming?
