NATPA Div. 5 Rules
New Rules
03-29-2004 18:45:48
I see the oliver pullers want new rpm rules for Div. 5. If the 460 560 have to go back to 30% over there actual rpm will the 88,s have to run off of there actual rpm or the 880 rpm. Both tractors will lose rpm. 460 loses 854 and the 88 loses 260.
FULLPULLER#1
03-30-2004 12:31:58
 Re: NATPA Div. 5 Rules in reply to New Rules , 03-29-2004 18:45:48
The rule should read 30%RPM of the tractor that is pulling;;;M-1600x30%=2080rpm;;;;460-1800x30%=2340rpm;;;;Oliver 880-1750x30%=2275rpm,,,,,NOW the way it is in Div-5, the RPM is set at what ever RPM that Bear wants,depending on the tractor that Bear is running!.
And then you ask," Why does Div-5 have so FEW tractors in it?".
Div 5
03-30-2004 18:27:06
 Re: Re: NATPA Div. 5 Rules in reply to FULLPULLER#1, 03-30-2004 12:31:58
This sound like the person who sent the letter to the hook magazine. Must be getting beat pretty bad to get it on the agenda at the April meeting. There are other tractors in other div. that are out rpm's but those people just find more power or just quit going to the pulls. Like some people say go big or go home! Or maybe just drop out of the div 5 and let the people who want to run those tractors be in a div 5 with just the 460-560.
yeah....
03-29-2004 19:53:25
then the farmalls are only running 300 rpms more than an 88 and not almost 1000!!!!! ! makes sense!!!! don't let bear tell you boys what to do!!
Oliver puller NATPA RULES
03-30-2004 18:59:16
 Re: Re: NATPA Div. 5 Rules in reply to yeah...., 03-29-2004 19:53:25
Hey if we are discussing rules on Oliver lets discuss this no 1600 heads, no 99 heads, no 7 main blocks, no 99 manifolds is this really fair? I think we being cheated here. I also think no MM 800 heads below division 5 is crap. Its to bad NATPA has to lose so many pullers due to rules like these. Now, if we could only get more USAP pulls close to my area!
Green weenie
03-30-2004 18:58:04
I am not a div.V puller, but I am a member, so as an observer I would like to say this, The Oliver that is doing all the crying now really didn't give a hoot about R.P.M. as long as he was the only fire breathing monster pulling 3500 lbs.with an 88. This guy has dominated this class for years until the last season when he got IH competition, I am sure if he gets a chance he will drop to 3250 to avoid serious competitors''' If you want to make this class right give everyone 3000r.p.m. across the board and get those 460,560,88 and like size tractors back in the 4500 pound class where they belong! just my fifty bucks and 2 cents worth.
New Rules
03-30-2004 20:41:28
 Re: Re: Re: NATPA Div. 5 Rules in reply to Green weenie, 03-30-2004 18:58:04
Good point Green Weenie the rpm issue needs to be fixed. Div 5. has changed alot in the last five years i remember the pull in Sterling Col. in 1998 had 11 tractors in 5500 lb. Div 5. This year there was three. Some weight classes don,t even have one tractor in div. 5 any more. Div. 5 will be dead in two more years if things don,t change.
Oliver Puller
03-30-2004 19:00:48
I agree 100%
A TRUE NATPA FAN
03-30-2004 19:53:28
 Re: Re: Re: Re: NATPA Div. 5 Rules in reply to Oliver Puller, 03-30-2004 19:00:48
AND THEN WHAT ARE YOU GOING TO DO WHEN A 1100CI MM SHOWS UP AT 3000RPM TO PULL IN THE 4500LB VEEEEERRRY INTERESTING
Oliver Puller
03-30-2004 20:38:47
 Re: Re: Re: Re: Re: NATPA Div. 5 Rules in reply to A TRUE NATPA FAN, 03-30-2004 19:53:28
I will enjoy ever pass he makes!!!!!
Red
03-31-2004 06:58:40
 Re: Re: Re: Re: Re: Re: NATPA Div. 5 Rules in reply to Oliver Puller, 03-30-2004 20:38:47
Get those 88's and 460's back up to the heavier classes like in the other divisions so that us guys with the AC's and H's can build a division 5 tractor and come play.
