tune up for a 77 Oliver
Keith
03-28-2004 03:15:02
Hello, I bought a 77 recently and the wires, plugs, etc are very old and in bad shape. I want to replace all of the electrical components but I am trying to look into the future here. I plan on making this a puller in a year or so and would like to tune it up with stuff that will work when it is a puller. I hate to buy all of the regular stuff now just to replace it with some hi performance items. My question is, should I go ahead with electronic ignition and a hot coil and different plugs now? Is the stock, worn out motor going to run okay with the good stuff?
Thanks,
Keith
Greg770
12-31-2005 06:46:17
 Re: tune up for a 77 Oliver in reply to Keith, 03-28-2004 03:15:02
I have a 770 Oliver that runs well.....for awile. In cold weather the carb frosts up and the motor seems to be starved for fuel. It will keep going for a short time if I use a lot of choke but eventually it will not keep running. It will restart easily, but as soon as I let out the clutch it will stop running. Any ideas?
770
03-28-2004 16:11:24
Electronic ign. won't hurt a thing... Plugs are only $10 a set and you'd put new ones with a new motor anyway. Buy good wires, They'll last a LONG time..... Good luck.
CASEPOWER
03-28-2004 11:50:30
If it's warn out I would re-build it, but electronic ignition wouldn't hurt it. If the distributor bushings have wear it will help a lot.
