distributor
super red
03-25-2004 14:55:15
I was told that rebuilding a M distributor using different springs would help a lot for performance, what kind ? where do you get them from?
ChadS
03-25-2004 14:59:11
 Re: distributor in reply to super red, 03-25-2004 14:55:15
You were told correct!! Use a Chevrolet recurve kit, available at any parts store, makes a world of difference in throttle response! Chad
oliver man
03-25-2004 16:28:14
 Re: Re: distributor in reply to ChadS, 03-25-2004 14:59:11
Chad,
would this recurve kit or something like it work for an oliver distributor? and are you the one who makes positive traction in the hook???
thanks.
Chads
03-25-2004 19:04:47
 Re: Re: Re: distributor in reply to oliver man, 03-25-2004 16:28:14
It will work for any of them! Yes, that is me in the hook ads. ChadS
a puller
03-27-2004 06:38:38
 Re: Re: Re: Re: distributor in reply to Chads, 03-25-2004 19:04:47
what about one for a JD A or MM U???
ChadS
03-27-2004 08:01:34
 Re: Re: Re: Re: Re: distributor in reply to a puller, 03-27-2004 06:38:38
ALL OF THEM! From what I have found out about these tractor distributors, is that they built them very heavy. The springs that are in them, will not do any good in a puller because they are way too strong to keep up with the speed of a higher compression engine, or a sudden change in rpm. With a pulling tractor, you need every advantage in technology to make them run correctly, just like drag racing, we all know that for high performance, stock parts just don't deliver the quality performance as to say a modified component. Most I have worked with, (JD) they develop a "POP" or sputters under accelleration, this is caused by possibly 3 reasons, the igntion timing is not working fast enough to fire the cyl on time, carbs are not jetted right, or the plugs. By changing all of the old stock parts out, like advance springs, stiffer governor lever springs (JD) carb mods, this is the only way you will get the most out of the engine you have. I guarentee, (LOL) that if you have done nothing with the ignition, carb, you have power hiding. Now mostly, it is not power you are looking for with the advance springs, you are looking for a change in the engines running characteristics. this will work wonders for throttle response, and have more accurate timing coming from the distributor. You know, we got into the argument last week about where to find power, some say bore em, stroke em. I say, tune em. all that big stroke and bore don't do you a dimes worth of good if you don't build parts to match the engines characteristics. Each engine is different, they have different specs for each individual setup. So, yes, the distributor springs will work in all the old distributors, and, the performance will be noticable. Hope this helps a bit! APULLER,, How is everything up in your area? Been raining solidly for the last few days here LOL ChadS
ChadS
03-25-2004 18:01:52
one in the same. ChadS
super red
03-25-2004 17:05:31
Chad is there a certain year of a recurve kit to get? or will any one work. just so I know what to ask for .
ChadS
03-25-2004 19:02:36
 Re: Re: Re: Re: distributor in reply to super red, 03-25-2004 17:05:31
from 75-82 will work fine. Any Chevrolet with HEI ingnition. the kit has 3 sets of springs, use. either the lightest, or 2nd lighteset in the kit. Hope this helps. Chad
super red
03-26-2004 12:47:01
 Re: Re: Re: Re: Re: distributor in reply to ChadS, 03-25-2004 19:02:36
thanks I will give it a try.is there anything I could do to the governor to snap it up more?
super red
03-25-2004 15:18:05
thanks for the reply . I just wanted to be sure before I started taking it apart .
