70 valves in Heisler head for A JD????
Luke
11-25-2001 15:22:23
I have a heisler head for a 41 A JD. Does anyone know what kind of valves can be used in one, or where I can get Heisler valves for it at? Thanks.
ya, 70 valves will work then
11-26-2001 11:19:07
 Re: 70 valves in Heisler head for A JD???? in reply to Luke, 11-25-2001 15:22:23
bye
Roy
11-26-2001 08:56:01
I have put 70 valves in a A head. The stems have to be shortened and the valve angle is different. Had the head ground to match the valve.
Luke
11-26-2001 08:41:21
For a 1941 styled A John Deere w/hi lo transmission. Luke
WTW
11-26-2001 08:21:04
Luke, Go to your John Deere dealer and order Model 70 (GAS) intake and exhaust valves as they will fit and work as a direct replacement for the "A" Hiesler valve without doing any modification to the head. The stems on the intakes may be a bit shorter but not enough to be an issue. Good Luck Dave W.
john
11-25-2001 18:46:52
is it for an unstyled A?
or a styled?
