New Aluminum Heads for G JD's...!!!
Ron
03-25-2004 06:11:03
Supposed to be good for Double the HP of a Heisler..!! HUGE Valves... Also Aluminum Blocks over 7.5" bore... Good for 4,500 RPM....
JD Gimpa
03-26-2004 19:28:31
 Re: New Aluminum Heads for G JD's...!!! in reply to Ron, 03-25-2004 06:11:03
What kind of drugs are you taking??? 4500 RPM from a 2 cyl. JD G !!!! Some people will beleve anything.
Super G
03-25-2004 15:53:19
I hope this is true. What kind of Hp would a person be looking at with thoes RPM's if it hold together? Who is going to produce this, and what price?
G-MAN
03-26-2004 07:47:05
 Re: Re: New Aluminum Heads for G JD's...!!! in reply to Super G, 03-25-2004 15:53:19
Probably not much more than a real engine running at 1500 rpm. For sure there would be no ability to "hold" the RPM at 4500 with near-zero reserve torue. It would go from 4500 to 1000 in no time once a load was applied. You'd play h#ll filling those big cylinders at that RPM, regardless of how big the valves are. Not to mention that this "fabled" aluminum block is going to do nothing to increase power. Somebody is playing on mom and dad's computer and blowing smoke. Or else there would be more info and a link to where you can purchase these "unobtainium" components. Notice there's no mention of the special carbs and manifolds that would absolutely be required to make the heads work? Not to mention that the piston speeds would be ungodly for even a stock-stroke "G" running at 4500 rpm.
buickanddeere
03-25-2004 11:47:52
I wouldn't try that rpm with titanium connecting rods, lightweight pistons, custom steel billet crank and flywheel. Some twit is going to try it and kill a bunch of people. The insurance costs will then end even the true stock classes and antique shows. Wonder if these heads have two intake ports unlike the lettered Deeres?
a puller
03-25-2004 10:31:04
thas kinda funny since they never made a heisler for a G....hahaha....
Johnboy5020
03-25-2004 10:19:57
Gotta to be nuts to turn and ole 2 cylinder Johnny 4500 RPM just my opinion.
70 plowboy
03-25-2004 08:39:00
interesting i never knew a aluminum head and block would keep a crank and flywheel together learn something everyday!!!!!
gota love those double yer power add`s entertaining to say the least!!! ROD
JD2830
03-25-2004 07:47:42
Where did you see this at
farmall
03-25-2004 09:04:25
 Re: Re: New Aluminum Heads for G JD's...!!! in reply to JD2830, 03-25-2004 07:47:42
Sounds like a Denny's commercial.
