PULLING STRATEGY FOR JOHN DEERE 520
MIKE LOKAI
03-23-2004 16:08:45
WHERE DOES A JOHN DEERE 520 FIT INTO THE PULLING SCHEME. BETTER TO USE FACTORY WHEEL WEIGHTS ALONG WITH FRONT FACTORY WEIGHTS, OR BETTER TO USE SUITCASE WEIGHTS BEHIND AXLE AND ALONG SIDE OF FRAME. SIGNED--STILL LEARNING THANKS FOR YOUR
INPUT
buickanddeere
03-25-2004 11:51:48
 Re: PULLING STRATEGY FOR JOHN DEERE 520 in reply to MIKE LOKAI, 03-23-2004 16:08:45
5500lb class in 2nd gear with old hard road worn 15.5x38 Firestone Traction Field and Road. Max legal drawbar height, air pressure for a flat bottom in the spinout holes and balance for/aft weight to lightly bounce the front as spinning out.
Houston
03-23-2004 16:24:44
You would be better off to use the suitcase weights because you can move them around better. You might even build a weight bracket out in front of the tractor by taking two pieces of flat steel and bolting them to the frame rails. Then take a shorter piece and weld it between the two other pieces at the front. I hope this helps you.
JDGnut
03-24-2004 10:51:49
 Re: Re: PULLING STRATEGY FOR JOHN DEERE 520 in reply to Houston , 03-23-2004 16:24:44
Some clubs only allow the wheel weights or stock weights in the Stock or Div I classes.. Adding hang on weights moves you in to a higher class.. I like the hang on for the reason mentioned above.. better placement.. and wheel weights can be PITA... JDGnut
