The most common broken part
Shaggy
03-22-2004 21:53:41
I was wondering whats the most common broken part on a Farmall mostly. But I am curious about all the rest too. Other than the POCKET book.
ChadS
03-24-2004 17:21:52
 Re: The most common broken part in reply to Shaggy, 03-22-2004 21:53:41
I find alot of driveshaft couplings loose, or worn on most tractors. usually have to repace the bolts, and the rubber/steel washers to keep the coupler from comming apart. Shaggy, do you have any Super C or 153 engines for parts? ChadS
Simple Answer
03-23-2004 15:38:06
Your Wallet
Jack
03-23-2004 09:58:03
As the most common in all the tractors I would have to say the front weight bracket if one comes down too hard fully loaded.Not all though,some are really well engineered and strong but I have witnessed more weight brackets breaking than any other part.Rear hubs are a close second.
a puller
03-23-2004 11:22:36
 Re: Re: The most common broken part in reply to Jack, 03-23-2004 09:58:03
i would say that in an engine its the crank, and in the rearend, its the spiders. I have heard that the bow gears on an M strip at the shaft..but i don't know for sure...
rule bender
03-23-2004 08:25:28
The most common broken part is the Pullers Pride if he pulling Red or Green!
rb
JDGnut
03-23-2004 07:07:44
On the Farmall's.. I just don't see how those little gears hold together in the trany... they do.. but look at the trany on a 2 cylinder Deere and then the trany on a Farmall.. Looks like a car trany.. lol.. JDGnut
Andy
03-23-2004 15:35:05
 Re: Re: The most common broken part in reply to JDGnut, 03-23-2004 07:07:44
JD 2 cyls needed heavier geard because of the lower engine rpms and higher gear ratios.
Jose
03-22-2004 22:16:59
On a Farmall most of it. Why do you think
they have sold out several times.
Farmall/International no longer exist.
Shaggy
03-23-2004 05:41:18
 Re: Re: The most common broken part in reply to Jose, 03-22-2004 22:16:59
To give the others a chance! Okay on any puller no matter what brand.
