oliver 77
nimrod
03-22-2004 17:23:56
I have a pulling oliver 77 with 3 3/4 pistons and a 1550 head, what type of plugs should I use now and what mix of gasoline???? any suggestions?
thanks.
770
03-23-2004 14:51:55
 Re: oliver 77 in reply to nimrod, 03-22-2004 17:23:56
If you don't have high compression, hi octane pump gas fis the bill. Sunoco 94 dyno's the same on my tractor as vp 112 mix. Too high of octane actually robs power.....
nimrod
03-23-2004 16:38:07
 Re: Re: oliver 77 in reply to 770, 03-23-2004 14:51:55
thanks for the info, I used to run turbo blue, wasn't sure if it helped or not??? guess not!
puller
03-23-2004 10:41:16
I use hi octane pump gas and autolite 386.
