Wheelie bars
Green 88
03-22-2004 16:40:29
I need to build a set of wheelie bars for my Oliver 77 and 88. Can anyone post or email me some pictures so I can get an idea of how to mount them and what they should look like. If you could also give a small description of what material you used it would be greatly appreciated. Thank you in advance. Jason
John
03-24-2004 20:26:30
 Re: Wheelie bars in reply to Green 88, 03-22-2004 16:40:29
third party image
I am gonna try a pic link of some M Farmall bars. Same concept would work but you may need to add some gussets on the axle mount since the axle isn't square and the flat is fairly small compaired to total diameter. Tubing is 1.5" OD .125" wall DOM. Black pipe such as 1.250" ID (water pipe measures inside, mechanical tubing on the outside) would probably be fine. I used DOM because I had it. Slipped a piece of 1.25" solid inside the end of the tubing and welded the "foot" to it then drilled through. With 2 holes in the solid peice I can slip the end out to pull and slide it back in out of the way for loading. Maybe you can see enough in the pic to help. A few more pics can be found @ http://photos.yahoo.com/johndear720
Jeff
03-23-2004 05:08:31
I am at work right now but have several pictures of mine that I can send when I get home.
Willie
03-23-2004 18:57:46
 Re: Re: Wheelie bars in reply to Jeff, 03-23-2004 05:08:31
Hey guys, I am also setting up a super 88 that I just bought, I would appreciate some pics or plans as well. Thanks, Willie
Jack
03-24-2004 06:11:08
 Re: Re: Re: Wheelie bars in reply to Willie, 03-23-2004 18:57:46
Good luck with yours,I haven't had mine but about four months but so far I like it better than anything else I had ever owned.
Green 88
03-23-2004 06:07:36
Jeff that would be great. Thank you very much. Jason
