wd allis pulling power advice
larry
03-21-2004 19:08:01
can any one tell me what i need to do to my stock wd45 engine to make it competive at the tractor pulls
KBMO
03-22-2004 07:52:55
 Re: wd allis pulling power advice in reply to larry, 03-21-2004 19:08:01
Depending on what class you are pulling I agree it will do well just stock. If it has the 45 motor in it, it will have great power to weight ratio just stock. If you are going to run DIV III or better type pulling you might want to consider some upgrades.... 175 allis cam and carburator will help for not much money, from there the sky is the limit. They can be made very big cubic inches for a light tractor but if you are going much over 300 CI you should go to a D-17 block.
Keith
03-22-2004 09:50:16
 Re: Re: wd allis pulling power advice in reply to KBMO, 03-22-2004 07:52:55
I am considering doing more with a WC. What advantage does a D17 block give? Someone had recommended this to me.
KBMO
03-22-2004 10:31:25
 Re: Re: Re: wd allis pulling power advice in reply to Keith, 03-22-2004 09:50:16
The D-17 engine or Gleaner E has larger main bearings and the block itself is stronger.... especially the center main. That is the weak spot on the allis motors. If you aren't going big the WD and WD-45 block are both lighter.
Agent Orange
03-21-2004 19:39:24
Not to sound funny but "Fill it with Gas" and go have fun. Unless you are pulling against big money and big motors the WD45 is very competitive.
And wear Orange Overalls
03-22-2004 05:16:09
 Re: Re: wd allis pulling power advice in reply to Agent Orange, 03-21-2004 19:39:24
