Intake Question?
Ohio G Puller
03-21-2004 18:48:59
I am wondering what is a good vacuum reading on the intake in inches.Do you want it high or low at high idle,or under load?
Any info would be appreciated.
TimC
03-22-2004 07:29:45
 Re: Intake Question? in reply to Ohio G Puller, 03-21-2004 18:48:59
28 inches at idle means you will probably have a lot of velocity, that's good or you have a large ci motor sucking on a small carb/intake/plenium. It can also mean that the timing events on the cam are good. At wot you should ready from 0 to maybe 5. If it is much higher then that might mean that the carb is a restriction to the motor.
idle 26 to 29 inches
half throttle 12 inchs???
wot under load near 0 to 5
Just a guess..... ..... ..... ..
