Oliver pullers
David H
03-20-2004 04:02:16
How can I get rid of some weight in the front of my 1900? I've seen people make lighter checkerboard grills, but out of what? Can I replace the old wheatland solid axle with some 2x4 square tubing or will that hold the weight? Please help. Thanks, David
A.P.
03-20-2004 17:35:06
 Re: Oliver pullers in reply to David H, 03-20-2004 04:02:16
You can build it out of wood, sheet metal (steel or aluminum), plastic and fiberglass with or without a foam core. The easiest is probably one made of wood. There used to be someone who advertized in the "Puller" every winter that made fiberglass ones. I think they were around $350. Maybe someone has their old issues handy and can look it up.
Did you ever solve your rear wheel (10 bolt)/hub problem?
A.P.
David H
03-21-2004 05:05:37
 Re: Re: Oliver pullers in reply to A.P., 03-20-2004 17:35:06
Well, the hubs is another story. I want to put weld on hubs (9 bolt) on the rear, but I haven't taken the old ones off to see if they are splined or tapered. Haven't quite figured that one out. I'll try to post a pic of my new project. Thanks for all the help! David
TimC
03-20-2004 11:47:25
The late model 880s converted to fiberglass grills. Yes make a light weight front end.
Jeff
03-20-2004 09:42:46
Off of a 1900 I would say make a grill out of aluminum square tubing or something then if you want ot keep the kinda stock appearance and wide front get a rowcrop front end or a Swartchz? (Spelling). I am guessing you could go to a narrow front if you want,Being as most everything else that i can think of on the front of my 1800 is motor I am not sure what else you could do. Helium in the front tires maybe??? LOL! OH go with aluminum rims also that will get a little more weight off also.
770
03-20-2004 05:32:23
Just imagine if you made a checkerboard grill out of wood and gave it 4 or 5 coats of paint so no-one would notice..... .hmmmmm mm????? ? It can be done..... ..
The Swami
03-20-2004 11:17:02
 Re: Re: Oliver pullers in reply to 770, 03-20-2004 05:32:23
Make it out of wood, seen it done, if you take the time they look really good, cant even tell if you're not looking for it.
