ChadS
Dan
03-18-2004 16:56:19
Chad, you said that when I am ready that you would send me info. on how much and where I would have to cut my cam, grind rods and block if I stroke my 350 crank one inch. It's time.
Thanks for all your help.
Dan
ChadS
03-19-2004 08:45:27
 Re: ChadS in reply to Dan, 03-18-2004 16:56:19
Send me an email, will give you some good info. Mostly is is block, rod, and cam work. I have some pics of a block all cleared out to give you some ideas on where to cut. Now just a point of interest to study, you will cuth through the oil gallery on the side of the block, just take some soft copper tubing, and make 4 of these small tubes, and push them into place, once you have them in place, you can use JB weld, or something along that line to hold it in place. you can lightly dent the tubing, to make the room you need. that is the hardest part of this operation. Send me an email, ChadS
