W-6 axle housings???
John
03-17-2004 11:48:02
Was wondering if I use the W-6 axle housing on a Farmall M if I could still mount weele bars hich atachments and fenders. Also was wondering if you just wust the outer housing and the m guts how does this work please explane in detal how to acomplish this.
John
Wild Horses
03-17-2004 12:26:42
 Re: W-6 axle housings??? in reply to John, 03-17-2004 11:48:02
The U-shaped hitch off the M won't bolt to the W6 housings. The hitch on the W6 bolted to the underside of the housing with a hinge mount. The wheelie bars depend on how your's are setup. If they bolt on with the M fender holes, no. If they come off the bolts to the rear end housing, yes. Basically the housings are not the same in shape. Likewise the axles are not interchangable. The W6 axles are splined not keyed. You will have to use the W6 axles with the W6 housings. Also, to my knowledge there are no bolt on 9-bolt hubs for the W6, you will have to use weld on hubs or the W6 cast centers.
