Laotto indoor pull
josh
03-16-2004 14:17:36
Just went to www.themotoplex.com they have the information on the pull such as dates,time and the classes.
josh
03-16-2004 17:27:19
 Re: Laotto indoor pull in reply to josh , 03-16-2004 14:17:36
Yes it is 14-9-38 or 15-5-38 max in the classes below 7500 for div 2. for 7500,8500 and 9500 the max tire size is 18-4-38.
binder winder
03-17-2004 10:15:33
 Re: Re: Laotto indoor pull in reply to josh , 03-16-2004 17:27:19
Are the rpm's for a IH 460 still 3000.
Josh
03-17-2004 16:35:02
 Re: Re: Re: Laotto indoor pull in reply to binder winder, 03-17-2004 10:15:33
We are going 10% for div 3,and 20% for div 4. So a stock 460 is 1981 rpms 10%is 2179 rpms and 20%is 2377 rpms.I hope this helps.
binder winder
03-17-2004 17:30:02
 Re: Re: Re: Re: Laotto indoor pull in reply to Josh , 03-17-2004 16:35:02
Josh I hope you bring that bad AC and leave the Oliver home,that way you'll at least have a chance to win.
ChadS
03-17-2004 10:54:40
it will be what the NATPA rpm specs say. I have my 460 set up for 3000 rpm, no more, no less. Hope this helps. ChadS
Wrenchbender
03-16-2004 17:05:24
I just checked out the rules at that site. It looks as if all the classes are 1959 and older including Div 2. I tried to e-mail "helper" but e-mail was returned. Is that correct Helper, also 15.5 tire size in all Div 2? Thanks, WB.
Correction
03-17-2004 07:23:20
 Re: Re: Laotto indoor pull in reply to Wrenchbender, 03-16-2004 17:05:24
The e-mail is [email protected] Laotto was spelled wrong on the fliers adress. If that doesn't work please post again.
Corrected - correction
03-17-2004 09:53:41
 Re: Re: Re: Laotto indoor pull in reply to Correction , 03-17-2004 07:23:20
Sorry, should be, [email protected] for information on the Laotto pull.
