ChadS
03-17-2004 08:46:35
Re: Roller Rockers or Pulling Cam in reply to MAD DUC, 03-16-2004 10:27:44
Well, I will give it a shot. LOL!! Sounds like you have a good set up for the engine block and pistons. If you do go with a re ground cam, get a smaller, less radical cam grind. Some say use later model grinds, some say they are the same. I know I had done that to a 41 A, and it ran smoother with the 60 cam grind. If it was me, I would keep it stock. Changing cams for performance is a difficult issue to discuss. It has to do with rpm, cubic inch, compression ratio. Since it is just a repower, (power block) you will have higher compression, but not enough to warrant a cam change or different ratio rockers. Put it together, and fine tune it!! Do all the little things, carb tuning, different ignition, change the mechanical advance springs in the dist, adjust the valves to get peak pressure from the cam you have. You would be surprised how much pressure you pick up from tuning the valve train, on 4-6 cyl on average of 10-20 psi more. Don't know about a Deere, but anything will be bennificial. On our deadweight puller, a 58 JD 730 Gas, I have fine tuned it on the dyno, and try to keep all of the traditional things from happening, like misfires, etc. The carb will help you the most in this case. One thing I feel strongly about is finding the right carb for the engine. I feel that the stock A carb is too big for the stock, or lightly modified A, under 150psi, On the 41A, I used the carb off of a B, and picked up a bunch of low end power. It is a smaller cfm carb than the A, and will handle the vacuum pressure better. The more vacuum you can put in the manifold, the more fuel you will put in the engine. Some say what about a big carb? Big CFM carbs, CFM ratings are based upon rpm, and cubic inch, and cam design. This is a low rpm engine, so you can slow the air flow down, and make better power with the smaller carb than a big one. Now, on a highly modified engine, yes, big carb will help, most go too big, and lose lug power, or it pops. So in my opinion, less, is more on a close to stock engine, as far as modifications go. Like I say, carb, ignition, and lots of fine tuning. and you will have one sweet running JD!! Just my 2 cents, ChadS
