stroke for IH 300 motor
Dave
03-13-2004 06:01:21
How much can you stroke a Ih 300 crank without having to grind out the inside of block? Do you use the same connecting rods? Thanks for you help.
Chads
03-14-2004 14:01:01
 Re: stroke for IH 300 motor in reply to Dave, 03-13-2004 06:01:21
5 inch stroke for no block work. You will have to grind down the rods, and the insides of the cam lobes to clear the rods, not much just a bit. I built a 3-13/16X 5 in H it was 62hp, with the H carb, and an old mag. if you use bore the block to fit 806 Ih pistons, you can use them up to 5-3/4 stroker and not have to buy new pistons, just remachine the tops when you add more stroke down the road. Hope this helps some, Chad
