Machining JD-B Block
Darol
03-12-2004 23:45:13
How much can be safely taken off the top of a 48 JD-B cylinder block...looking to raise compression. I have heard you can take off as much as a 1/4". It already has a set of .090 over M&W's.
Thanks,
Darol
Jerry
03-13-2004 13:09:47
 Re: Machining JD-B Block in reply to Darol, 03-12-2004 23:45:13
You might be able to raise your compression with a set of 3/8 x 3/8 square stock rolled into a circle, machined and held in the top of the block with set screws,
Green Weenie
03-13-2004 19:24:27
 Re: Re: Machining JD-B Block in reply to Jerry, 03-13-2004 13:09:47
Why not just glue an old basket ball in their then you can raise and lower the compression as you wish with an air hose.
