JD 60 Stuck in Reverse
The Rodent
03-12-2004 12:19:17
I have just gotten a JD 60, and when I backed it off the trailer it got stuck in reverse. Well, anyway I finaaly got it out, all the other gears work great. But someday I might want to back up. What could be the trouble? Any ideas? Thanks
mike
03-12-2004 19:08:17
 Re: JD 60 Stuck in Reverse in reply to The Rodent , 03-12-2004 12:19:17
You are saying that reverse wont work at all , or it is hard to get out of reverse when the tractor is running, pretty hard to mess up reverse, would be easier to explain if it was a forward gear, what did you have to do to get it out?
Rodent
03-13-2004 21:03:11
 Re: Re: JD 60 Stuck in Reverse in reply to mike, 03-12-2004 19:08:17
Yes it works in reverse,but it is hard to get it out. With the tractor running,you have to hit it hard several times as you move the clutch lever.THANKS FOR THE HELP!!!
