Tires for WD puller
Nate
11-17-2001 14:09:43
I am in bad need of new tires. Should I go to a taller tire like a 38 or stay with my short 28's? I pull in the 3mph class and am afraid the 38's will make me too fast. Should I run the widest tire allowed? Thanks
Nate
11-19-2001 18:26:57
 Re: Tires for WD puller in reply to Nate, 11-17-2001 14:09:43
We can run up to 16.9 38 in under 6500 lb. class.
Kraig
11-19-2001 06:19:25
Where I am located, I can run only stock tire sizes, which mean 13.6 x 28.
RD.
12-15-2001 15:52:41
 Re: Re: Tires for WD puller in reply to Kraig, 11-19-2001 06:19:25
Our WD-45's came with 13x28 tires, which is the same as 14.9x28..... 13.6x28 is a lot smaller... We have used these, and always pull 4-14" plows, in 2nd gear... Our tires ARE loaded, and a weight is bolted to the front....
