Turbo on 8000 Ford
Wally G.
03-10-2004 17:55:56
Any Ford pullers have a suggestion for a turbo for hot stock on a 8000? What about cylinder head and injectors?
raymond
04-02-2004 21:25:46
 Re: Turbo on 8000 Ford in reply to Wally G., 03-10-2004 17:55:56
You need to contact the Forresters at>Link
They>Link know everything that there is to know about what you need. Also, post this question at www.pulloff.com and you will get alot of good advise on your old 401.
856
03-11-2004 14:56:39
I helped a guy build a 8000. the pump was built but the head didnt flow. we got to apx. 325hp. after that all we could do was make smoke. it was fun to watch though
BigART
03-10-2004 18:48:54
Paul Yates, listed as P-c-y on pulloff.com had some stock turbo's off of 474 fords, said they were pretty aggressive, if your going to turn some rpm, and build the pump, you may want to look at a 3lm466, or something similiar in size.
Paul may have injectors and lines also. BigART
Wally G.
03-11-2004 09:07:51
 Re: Re: Turbo on 8000 Ford in reply to BigART, 03-10-2004 18:48:54
Thanks BigART, I'll pass it on to the man building the machine.
