Need Carb Help !!!
Lamont
03-08-2004 17:42:38
I'm building a GASOLINE 336 cubic inch CASE. It will have around 10 to 1 compression and I'm wanting to run around 3500 RPM max. The cam has been reground and I'm wanting to run the stock intake and need help finding a carb to get the job done. Can anyone on here help? Thanks in advance.
TimC
03-10-2004 06:00:15
 Re: Need Carb Help !!! in reply to Lamont, 03-08-2004 17:42:38
336 X3500 X .75 /187200 = 4.711 area converted to dia = 2.45 inch venturi.
Formula is CID X RPM X VE DIVIDED BY 187200= AREA
To get the most out of it at 3500 you should need this. It might be to much if it pulls down in the rpm range. You can also find on line engine calculators on the net.
Lamont
03-11-2004 21:05:38
 Re: Re: Need Carb Help !!! in reply to TimC, 03-10-2004 06:00:15
The VE in the formula: What is it? Thanks for your help.
Two-Tone
03-09-2004 08:30:20
For a Case the best carb would be from a 960 FORD! Ha Ha. see you soon.
tt
Lamont
03-09-2004 17:52:16
 Re: Re: Need Carb Help !!! in reply to Two-Tone, 03-09-2004 08:30:20
Can I borrow yours? Hope everything is going well with ya Two-Tone. I also need you recipe for your patented Whoop Gas.
Lamont
