spark plugs
glen
03-06-2004 02:46:19
I would like to try using automotive plugs in a JD G with plug adapters. Wondering what plugs anyone has used, anyone used the splitfire ones? Been using Champion D16-D21, also AC but foul an awful lot of plugs. This is a pulling tractor with 11-1 comp. Thanks.
Hank
03-06-2004 16:31:28
 Re: spark plugs in reply to glen, 03-06-2004 02:46:19
Give DENSO plugs a try.
zig
03-06-2004 14:50:44
Use autolite 3116 you wont be disapionted work real goog you wont foul this plug and has agood heat range
lynn
03-06-2004 12:36:02
glen..we use ac 42 to 44 depending on the tractor..dyno them and read the plugs and go from there..change plugs every pull and bead blast the old ones and put some wd40 on them so they won't rust and reuse them..lynn
Roger
03-06-2004 05:31:56
Save your money. Do not use splitfire spark plugs, there is no advanage.
Champion D-21 should work if everything else, as far as points, coil, and timing are OK.
farmall
03-06-2004 09:13:39
 Re: Re: spark plugs in reply to Roger, 03-06-2004 05:31:56
You need to look at the Champion truck plugs.
The 4130 Champion will fit right in place of the D21 Champions. The extended tip could be a problem though on the JD's. Check for piston
clearance first. I have had very good luck
with these plugs.
Karl
03-06-2004 21:15:24
 Re: Re: Re: spark plugs in reply to farmall, 03-06-2004 09:13:39
GO with the autolight 3116.
glen
03-07-2004 08:10:17
 Re: Re: Re: Re: spark plugs in reply to Karl, 03-06-2004 21:15:24
What gap are you guys using?
zig
03-08-2004 15:28:37
 Re: Re: Re: Re: Re: spark plugs in reply to glen, 03-07-2004 08:10:17
035 i run them in my G with 13 .1 compresion elctronic ignition ben running 3 years no problem so far
