Need a stroked crank
crankneeder
03-04-2004 20:36:54
i need a crank with a small stroke for a JD A. would perfer one somwheres' around 7.375" stroke. If I can't find a used one, where is the best place for the money to have a crank done? am trying to get a 55/60hp tractor running for this summer....thanks alot
ChadS
03-06-2004 09:53:14
 Re: Need a stroked crank in reply to crankneeder, 03-04-2004 20:36:54
There is a stroker set up for an A JD in the classified here at YT. ChadS
2 Cylinder
03-05-2004 14:51:20
You can obtain 55-60hp by using a Powerblock with high compression aluminum 6.125' pistons, Big Nut G Carb. porting the manifold and head, cold manifold and milling the head, 3 angle valve job on oversize valves,and remove the oil bath system in favor of a K&N filter.
Jim Jones
03-05-2004 12:22:09
You can get that without stroking it---Just raise the compression----good valve job----change the camshaft configuration----unrestrick the air supply---- Good luck--Jim
jdpullergb
03-13-2004 06:58:13
 Re: Re: Need a stroked crank in reply to Jim Jones, 03-05-2004 12:22:09
you can get 55-60 hp by what 2cylinder said i saw it pull real good tractor.
