MM U
puller
03-04-2004 20:28:53
I would like to know what crankcase I should/or have to use for a 7.5" crank and massy rods with a 2.5" journal. What all has to be done to make a good strong tractor.? what about the center main???thanks alot, puller
DH
03-05-2004 17:39:56
 Re: MM U in reply to puller, 03-04-2004 20:28:53
The 670 super is definitly the strongest the Crank will fit fine and the U front cover will fit you have to use a 670 flywheel for a foot clutch or a Late 336 power unit flywheel for a hand clutch. I have an extra one if you are interested.
Mopower
03-05-2004 04:17:52
The M670 Super crankcase is superior to all other U type bottom ends. There is more "beef" to it and more reinforcement in the center main. I found this out recently and saw it first hand. In a high horsepower situation it holds together well! I'd give that a try. Sounds like quite the project you got going there. Good luck.
puller
03-05-2004 09:11:12
 Re: Re: MM U in reply to Mopower, 03-05-2004 04:17:52
yes, well, we were all Jd tractors before, but fell in love with the moline i saw pull that was rather small (100hp). i have a crank spoken for with a 7.5" stroke and am looking into the best way to get it to fit. thanks for the help, the one question i still have is will the G 4cyl crank all line up with the super 670? thanks alot for the help. will post a picture in the future of the progress.
Mopower
03-05-2004 14:57:18
 Re: Re: Re: MM U in reply to puller, 03-05-2004 09:11:12
Yeah, I belive it will line up. The long stroke might require some grinding and so on. Seen a couple UBs running 200 with 7" strokes.
gee
03-06-2004 08:01:09
 Re: Re: Re: Re: MM U in reply to Mopower, 03-05-2004 14:57:18
who did the massey rods
