JD A custom pistons
Joe
03-02-2004 19:47:57
I was wondering if someone can help. I am looking to build a pulling tractor.
I was wondering where I can get 6.5" or 6.25" pistons. I want to keep them short so that I can use a 9" stroke.
If I need to get custom ones made, who can do these for me?
thanks
jpdunn
03-04-2004 20:36:47
 Re: JD A custom pistons in reply to Joe, 03-02-2004 19:47:57
Have you considered 6.125 used aircraft pistons with a 9.25 or 9.375 stroke?
JD2830
03-05-2004 12:11:03
 Re: Re: JD A custom pistons in reply to jpdunn, 03-04-2004 20:36:47
Does Jahns pistons have a website
WTW
03-03-2004 08:04:48
Joe, I just sent the drawings to Jahn's Pistons in Los Angles Ca. for a 9" stroker "A" with a power block. If you are running a power block just tell him to copy mine with the bore size that you want and have your bank card ready. Will run you in the neighborhood of $600.00 for two pistons and pins. These pistons will let you run a rod length of 14.125" His toll free number is: 1-800-225-0277. Good Luck! Dave W.
Joe
03-03-2004 15:04:45
 Re: Re: JD A custom pistons in reply to WTW, 03-03-2004 08:04:48
Thanks, What bore size are those? I am going to put it in a regular A block that has welded in sleaves. How high are these pistons and where are you setting the pins? What size pins are you going to put in? I appreciate all the help.
WTW
03-04-2004 07:42:31
 Re: Re: Re: JD A custom pistons in reply to Joe, 03-03-2004 15:04:45
Joe, These pistons are for a Power-block and have a pointed top to reach up in closed end of PB to maintain compression ratio. They are 6.125 in diameter and have a CD (compression distance) of 2.375. I can get the CD down to 2.0 if you do not need a stepped or pointed end on the head end them. I use the stock 1.75 pin / diameter. I run the oil ring in the stock location below the pin. Able to do this by adding the 1/2 the amount of stroke to rod length. Example if I stoke an engine 2" lengthen the rod 1" and shorten the compression distance on piston 2". This keeps then oil ring and piston pin in the same original running location. Not all engines you can do this but I have many two cylinders this way. Makes some interesting piston designs!! Piston have two compression rings. This will get your brain thinking. Good Luck, Dave W.
JDGnut
03-04-2004 08:17:40
 Re: Re: Re: Re: JD A custom pistons in reply to WTW, 03-04-2004 07:42:31
WTW... Which style of head are Running with this PB... When the time comes I'll be using the 60 Head.. Just curious...
JDGnut
WTW
03-04-2004 08:41:48
 Re: Re: Re: Re: Re: JD A custom pistons in reply to JDGnut, 03-04-2004 08:17:40
This one will have a Heisler. You will need more crown on piston to run your 60 head. It will work, just have to allow for the extra room in combustion chamber by altering piston height. DW
ChadS
03-03-2004 08:22:49
WTW,, sounds like you are building another winner!! If you can make those B JD run the way they do, I would love to see what an A would be like. Have a good one!! ChadS
WTW
03-03-2004 08:51:32
 Re: Re: Re: JD A custom pistons in reply to ChadS, 03-03-2004 08:22:49
Just helping another fellow out with his project. The bad part is my son will have to pull against this "A" in the heavier classes that we pull in with his "B". It makes better stories when you can beat a bigger one anyway! Haven't been to any winter pulls other than the Thanksgiving pull at Princeton Ind. Would like to go but just to many things on my plate right now. The boy is looking forward to going to Sigourney Ia. pull. We usually go to that one and have a good time. (Less than 100 miles from home.) Good pull to go to. Would also like to go to Fruitland Missouri and really wanted to go, but cannot take the time to do it. Have a late model 1972 4020 doing a complete restoration on for one guy and a 4010 Super farm pulling tractor for another guy with the engine down that needs to be put back together besides all my own tractor and home projects to do. I won't be pulling this summer if I don't get some of them done!! Hope you don't have this much to do to keep you from pulling, People seem to forget that I work a full time job in town and this wrenching thing is just something a do for an extra buck! Maybe we will bump heads next winter somewhere. Take Care, Dave
JDGnut
03-03-2004 14:23:37
 Re: Re: Re: Re: JD A custom pistons in reply to WTW, 03-03-2004 08:51:32
If U dont get that deck on the house finished???!!! lol
I guess that is for the A powerblock I once saw the piston removed in a new format??? Picked U my new toy... have to get the other tractor finised first.. if it would quit raining I could get some Green on..... JDGnut
WTW
03-04-2004 07:25:01
 Re: Re: Re: Re: Re: JD A custom pistons in reply to JDGnut, 03-03-2004 14:23:37
You know the program! I got allot of material bought for the deck all I am short now is time! Been raining here too kind of muddy and cold around the outside of the house. Too muddy to tolerate. DW
