diamond T motors for pulling
redfarm
02-29-2004 19:35:25
can you use a 450 or 501 diamond T motors for pulling ? how much are they worth?
dean
03-01-2004 18:40:48
 Re: diamond T motors for pulling in reply to redfarm, 02-29-2004 19:35:25
401 450 and 501 all had 1/2 inch more stroke than the smaller engines..401 and 450 will fit in a w-40 if changing front cover and balancer will fit..501 has larger crank snout so front cover and balancer need to be modified..would be helpful if you indicated what tractor you were working on?...also 450 and 401 had removable sleeves and 501 did not..most info on the motors are available in the old motors books that were put out for servicing big trucks. the truck blocks are easy to detect because of the pad on front that is stamped with the size and also the freeze plugs that are not found in the tractor blocks. so be sure that your pulling organization will aloow for non stock blocks...
LW
03-01-2004 08:18:19
Do you mean Red Diamond?
redfarm
03-01-2004 09:33:02
 Re: Re: diamond T motors for pulling in reply to LW, 03-01-2004 08:18:19
yes red diamond.
ChadS
03-01-2004 10:32:12
 Re: Re: Re: diamond T motors for pulling in reply to redfarm, 03-01-2004 09:33:02
The RD engines seem to be the engine of choice for IH W-40, 460-560-660. Heck, 199 hp stock (RD450)at 3000 rpm and little work to put it in, who wouldn't run one? Just my 2 cents, Chads
redfarm
03-01-2004 13:09:12
 Re: Re: Re: Re: diamond T motors for pulling in reply to ChadS, 03-01-2004 10:32:12
How much are they worth? Will a 501 fit too?
Cody
03-01-2004 14:29:15
 Re: Re: Re: Re: Re: diamond T motors for pulling in reply to redfarm, 03-01-2004 13:09:12
Do you have a 501 that you're wanting to sell?
TimC
03-01-2004 13:55:09
Will not fit in stock form but can be made to fit.
ChadS
03-01-2004 13:16:01
The 501 is the same block as the 450. I would say that anywhere from 250-1000 price range. 250 being needed rebuilt but runs, and 1000 being complete and maybe rebuilt or low milage. It will fit.
LW
03-01-2004 16:45:41
 Re: Re: Re: Re: Re: Re: diamond T motors for pulli in reply to ChadS, 03-01-2004 13:16:01
The 501 RD is not the same block it has a higher camshaft and the front cover is not interchangable check your info!
560puller
03-01-2004 18:30:20
 Re: Re: Re: Re: Re: Re: Re: diamond T motors for p in reply to LW, 03-01-2004 16:45:41
Where do you guys come up with information about what truck engines will fit what tractors? Just curious. Which IH trucks had a big engine that would fit in my 460?
redfarm
03-01-2004 19:14:45
 Re: Re: Re: Re: Re: Re: Re: Re: diamond T motors f in reply to 560puller, 03-01-2004 18:30:20
How big can you make a 450 and 501 motor?
LW
03-01-2004 19:42:34
 Re: Re: Re: Re: Re: Re: Re: Re: Re: diamond T moto in reply to redfarm, 03-01-2004 19:14:45
Seriously How much money you got that is the major limiter.
