John Deere B valves
Roger
02-29-2004 12:09:18
I am in the process of putting bigger valves in my 48 John Deere B. I was going to try and put A valves in it, however in looking at some A valves I have there is no way they will fit. Are 50, 520, or 530 valves bigger, and if so can they be machined to fit? Appreciate any help on this.
Kenny
03-01-2004 15:50:07
 Re: John Deere B valves in reply to Roger, 02-29-2004 12:09:18
Roger I have a 44 B and put unstyled A valves in it.Schoolers put them in for me works real good. Kenny
Roger
03-02-2004 04:34:56
 Re: Re: John Deere B valves in reply to Kenny, 03-01-2004 15:50:07
Kenny, appreciate your reply. The later styled John Deere B had a bigger engine then the early styled. My question, is the diameter of the A unstyled valve stems, the same diameter as the valve stems on your 44 B or did you have to have them machined to fit? Also, the valves on the A are they a lot bigger diameter, both the exhaust and intake then the B valves? Again, appreciate your reply.
Roger
