M stroke
dave h
11-12-2001 17:34:28
what is the most you can bore and stroke a M without disturbing the internal webbing in crankcase, and sleeving into water jacket?
Red Man Rising
11-14-2001 13:58:40
 Re: m stroke in reply to dave h, 11-12-2001 17:34:28
I would like to know if I can bore my 400 {264} block to 4.375 without hitting a water jacket or having to run a sleeve. That's 4 3/8 inches. Is there enough meat?
Red Man Rising
11-14-2001 13:58:34
deere john
11-15-2001 05:10:04
 Re: Re: m stroke in reply to Red Man Rising, 11-14-2001 13:58:34
Those engines have sleaves
dave h
11-15-2001 10:50:25
 Re: Re: Re: m stroke in reply to deere john, 11-15-2001 05:10:04
I know, club rules state no disturbing of the water jacket or webbing.
get real
11-15-2001 13:28:37
 Re: Re: Re: Re: m stroke in reply to dave h, 11-15-2001 10:50:25
do they have x-ray glasses where they look thru block?? what kind of stupid rule is that!!!!! !!!!!
dave
11-15-2001 14:24:34
 Re: Re: Re: Re: Re: m stroke in reply to get real, 11-15-2001 13:28:37
they will require any one they suspect to drop the oil pan. or the head. If ok the club pays to replace the gaskets. in 15 years this has happened only once. there pulls are run real well. almost all the tractors in this class finish within ten feet of each other. in an open class.only those who would try to cheat worry about it.they had a block explode once I guess and someone got hurt. the rule allows you to go open rpm with saftey
