Maxium Compresion
Dave S
02-26-2004 01:07:38
Hi, I'm looking for opions on what would be a good compresion ratio for my pulling tractor.Having a set of Ross Custom pistons made. Here's my specs: DC Case with 4 1/16th bore and 5 1/2" stroke. Stock head already recondition so not going to port or install larger valves. Berry groung cam increased lift only. Larger M/S carb with intake ported to match. Dist. w/electronic and hot coil. Stock RPM 1390, 1200 rpm govenered. Thinking of 11.1. How will this respond? Thanks, Dave S
CASEPOWER
02-26-2004 06:37:25
 Re: Maxium Compresion in reply to Dave S, 02-26-2004 01:07:38
Should do fine, but unless the ross pistons are domed you won't get 11 to 1. The best CC's you will get from a 5505 gas head is 150 cc's and with your bore and stoke and pistons at deck height you will end up around 8.5 to 1 comp.
