What is the best tire size for pulling with an Oliver super 77?
Gary M
11-10-2001 15:48:39
I need new rubber and would like to only buy rubber once. i have 38x13.6 on here now. should i get new? used {cleats worn}? same size? wider?
who has experience in this? i will be hitting County fairs in Central Michigan, so i wont be much competition to 90% of the nation. that is until i get a Pratt&Whitney R4360 Radial Aircraft engine mounted onto something that can handle 2400+ shaft horsepower.
Banjoliver
11-20-2001 22:31:57
 Re: What is the best tire size for pulling with an Oliver super 77? in reply to Gary M, 11-10-2001 15:48:39
Each tractor pull can have its own rules, but generally, if you pull in farm stock or field stock, you have to stick with stock size uncut tires like your 13.6 x 38. If you pull classic, you can go to 14.9 or 15.5 cut tires (or even bigger if you pull open class). Used tires are usually better, because the rubber is harder and the cut lugs don't wear as fast and they dig in better.
