engine size
Jim M
02-18-2004 09:51:07
Does anyone have the forumla to calculate the cid of an engine.
a puller
02-18-2004 11:34:58
 Re: engine size in reply to Jim M, 02-18-2004 09:51:07
((bore/2)squared(3.141592653)(stroke))x # of cylinders= cid.
go to www.robertscarbrepair.com then click on technical information, then click on the calculate cubic inches
farmall
02-18-2004 11:32:54
Take the bore x itself (bore squared) x .7854
x stroke x number of cylinders = cid
Hope this helps
a puller
02-18-2004 15:39:15
 Re: Re: engine size in reply to farmall, 02-18-2004 11:32:54
what is the .7854 in this equation? I haven't figured this out yet..... thanks in advance...
farmall
02-18-2004 18:56:50
 Re: Re: Re: engine size in reply to a puller, 02-18-2004 15:39:15
The radious squared x pie(3.141592654) is the same as;
bore squared x .7854 Its just a short cut that I thought was common knowledge. Hope this helps
Drew
02-18-2004 15:48:37
.7854 is an approximation of pi/4
a puller
02-18-2004 17:25:22
 Re: Re: Re: Re: engine size in reply to Drew, 02-18-2004 15:48:37
why would you divide pi by 4? what is the reasoning? thanks alot
Augie
02-18-2004 11:02:48
Try this...
WILDMAN
02-18-2004 10:01:49
.7854*BORE*BORE*STOKE*NUMBER OF CYLINDERS
Mopower
02-18-2004 09:57:22
(Bore size) X (Bore size) X (Stroke) X (# of cyl) X (.785) = Engine cubes. (use inches)
That's one way.
