Tire/rim combo
A-man
11-07-2001 18:14:08
Right now on my '51 JD "A" I have the original 13.6 -38s tire on a 12 inch rim... I am not getting enough traction at the tractor pulls! I have an older set of 15.5-38s available, but I don't know how well they will fit the 12 inch rim... Will they? Or do I have to find a 14 inch rim for these tires? If so, What kind of 14 inch rim will bolt up to the "A" cast iron centers? Thanks.!
mike
11-09-2001 02:37:10
 Re: Tire/rim combo in reply to A-man, 11-07-2001 18:14:08
got a pair of 16 x 38 rims that i would sell
A-man
11-09-2001 07:18:57
 Re: Re: Tire/rim combo in reply to mike, 11-09-2001 02:37:10
Ummmmm m..... . I need to fit 15.5 tires on my "A" .... That is the biggest tire allowed in my weight class. I think a 16 inch rim is 2 inches too wide... I need a pair of 14x38 rims... But thanks for the offer!
G Taylor
11-10-2001 10:25:42
 Re: Re: Re: Tire/rim combo in reply to A-man, 11-09-2001 07:18:57
The 16" rims are ideal for 15.5x38 tires. They reduce side wall & tread buckling so the tread bars are held straighter to bite into the track better.
AL
11-08-2001 05:11:13
USE THE 13.6 'S AT A LIGHTER WEIGHT..OR ..PUT ON MORE WEIGHT TO UTILIZE THE 15.5'S..AL
A-man
11-08-2001 06:08:04
 Re: Re: Tire/rim combo in reply to AL, 11-08-2001 05:11:13
BUT, will the 15.5s successfully fit a 12 inch rim?
Mike
11-08-2001 07:05:50
 Re: Re: Re: Tire/rim combo in reply to A-man, 11-08-2001 06:08:04
the 15.5s will go on a 12" rim but will have to much center crown and will not put down a good footprint. New 16 38 dropcenter rims can be had for about 140$ apiece and that is what I'd reccomend. If your 12" rims are in good shape you should get 50-75 apiece for them. 15.5s supposed to go on 14" rim
A-man
11-08-2001 07:36:34
 Re: Re: Re: Re: Tire/rim combo in reply to Mike, 11-08-2001 07:05:50
Ok! thank you for the advice! I'll try finding a new or used set of rims.
