Stroking
Matt
02-15-2004 17:20:26
How much can an Farmall 300 gas motor be storked while still using the stock rods? Any suggestions on a piston and strock setups?? Thanks.
farmall
02-16-2004 06:37:58
 Re: Stroking in reply to Matt, 02-15-2004 17:20:26
If the rods are narrowed for cam clearence, and machined around the big end, the most stroke that I have been able to fit in a 300 is 5.75 stroke.
Hope this helps
ChadS
02-16-2004 07:03:17
 Re: Re: Stroking in reply to farmall, 02-16-2004 06:37:58
Another point to bring up on the 5-3/4 stroker, is depending on how the rod journal is designed after it has been welded for a stock rod journal size, is that the crank will hit the cam, if it is ground so it is narrow at the tip of the journal, you will need a bit more clearance to clear the cam. keep the journals narrow on the end of the cranks, otherwise you may have to grind on the crank to clear the camshaft. Chad
ChadS
02-15-2004 17:31:49
1 inch easy, block, cam and rod clearance work required, can go bigger with stock rod,, email me, if you like, will go into detail, Chad
