Pulling JD R's and 830's
The Rodent
02-14-2004 15:59:27
Which is better.... a pulling John Deere R, or a John Deere 830. Why?
Paul
02-14-2004 17:35:25
 Re: Pulling JD R's and 830's in reply to The Rodent , 02-14-2004 15:59:27
virtually no difference in div.1 or 2.however if you reaaly want to build a big bad 2 cyl diesel. an 80-830 is the place to start. an R has only two main bearings and if leaned on hard and long enough the cranks can and do fail. a 9"x 6.25" combo with big pumps can turn out probably 125 horse. probably near a 100 with 8"x6.125. they make 8"power blocks for the 80-830 9" crank could get you well over 200 horse.Paul
brian
02-18-2004 10:18:32
 Re: Re: Pulling JD R's and 830's in reply to Paul, 02-14-2004 17:35:25
can i do all that with a 730 diesel or a 630 gas please get back to me as soon as u can so i can get it done by spring
a puller
02-15-2004 07:28:05
where could I get ahold of these 8" powerblocks? I might be interested in finding a 820 if that kinda horse can be made!! thanks alot.
Paul
02-15-2004 11:35:59
 Re: Re: Re: Pulling JD R's and 830's in reply to a puller, 02-15-2004 07:28:05
carlile(spelling) engineering somwhere in corolinas I think Check About year old HOOK magazine.Paul
CASEPOWER
02-14-2004 16:45:18
830 center main and much more
