Leroi power unit motors for AC's????
Goin Orange??
02-13-2004 20:03:02
Hey guys, I pull a WC and am planning on doing some work to the motor this year. I have heard different people mention getting this part and that part from Leroi power units, can someone please enlighten me about them?? Where do you get them, what makes them so special, etc. I heard they had a counterbalanced crankshaft, is that right? Are they the same as the WD's or are they newer like a D17, thanks for any help guys!!
buickanddeere
02-16-2004 17:22:58
 Re: Leroi power unit motors for AC's???? in reply to Goin Orange??, 02-13-2004 20:03:02
What is a Leroi?
Bill
02-14-2004 15:52:09
They are most commonly found in the Leroi portable air compressors. The ones we have had had the thrust brg on the front main. The crank was the same a wd 45 but the block and front cap were slightly wider since the leroi brg was not available we remachined the block and cap to accept the allis brg. I have heard of the leroi with the thrust in the center but never seen one. The manifolds are the most desirable piece i saw on them. The crank wasnt counterbalanced but looked to be made a little beefier.
Allis
02-13-2004 23:32:47
I have a couple of leroi crankshafts, 4 & 4.5 stroke, they take the same berrings as the wc wd engines but the thrust surface on the front will need to be ground to the ac specs because leroi put the thrust berring in the center. Not a problem. There are some extra weights on the throws. I also have some other parts if you are interested, head, header and cam and a GM ignition unit I put in the allis drive, some 45 cranks, let me know if you are interested.
puller
02-18-2004 11:28:32
 Re: Re: Leroi power unit motors for AC's???? in reply to Allis, 02-13-2004 23:32:47
how much would you have to have for the header. also how much for a 45 crank?
thanks John
