Farmall H/ 300 manifold
Farm w/Junk
02-11-2004 18:31:25
Hi I was wondering if the manifold of a 300 utility will fit an H? Will there be and advantages to having it? Will a 300 or 350 cam help much? Thanks
Matt
FULLPULLER#1
02-12-2004 17:56:08
 Re: Farmall H/ 300 manifold in reply to Farm w/Junk, 02-11-2004 18:31:25
Yes, 300,350,SH,all work on an H , as well the cams will go right in.....Now if your looking to boost up your H then this is what you do,,bolt the 350 head,manifold,cam and carb on your H block, you will pickup some power and torque,to get the best out of your H with these parts, you will need to stick the 350 motor and all in your H and pull it,If you can't pull this because of your clubs rules,then take your H motor, throw out the sleves and bore the holes out to a safe limit and install new pistons with a 1/4 inch dome bolt the 350 head,manifold,carb,and cam on and PULL!,,don't forget to dial in your cam at about 102dg, this will give you some good low end. Hope this got ya thinking.
