806
JOHN
02-11-2004 18:24:02
Is it possible to remove the complete 3pt lift under the seat on a 806.One line comes from the brakes and goes into the plate.IT appears to a return line.Getting rid of that huge peice of cast will cut alot of weight.
Bill
02-11-2004 20:21:53
 Re: 806 in reply to JOHN, 02-11-2004 18:24:02
Yes you can. I used to own a 706 puller and the guy I bought it from had removed it from the tractor. It will cut about 1,000lbs of weight. As far as the lines I can't tell you.
RBf
02-12-2004 05:31:54
 Re: Re: 806 in reply to Bill, 02-11-2004 20:21:53
The line you refer to is the brake return line, thats not a problem. You will have to remove the hitch pump and plug the pickup tube hole in the filter housing. Also there will be an issue with ring and pinion lubrication.
