Hey Puller re Oil Pump
TimC
02-11-2004 18:06:32
Contact Haldex Barnes on the web and have them check out these two numbers.
1002408 and 10397
Straight off the plate on the pump.
It is running one to one right now from a 6.5 inch pulley on the crank to a 6.5 inch pulley on the pump.
greatfull puller
02-11-2004 21:00:43
 Re: Hey Puller re Oil Pump in reply to TimC, 02-11-2004 18:06:32
I see now what the ## is
greatfull puller
02-11-2004 20:53:24
Thanks for the information!! Is this the numbers off the pulleys? and is that a V belt or one of those high performance jobs with the notches in it? thanks again!
TimC
02-12-2004 06:06:50
 Re: Re: Hey Puller re Oil Pump in reply to greatfull puller, 02-11-2004 20:53:24
V-belt. Standard.
No identifing marks beside those numbers on pump.
I'l' bet they also have some sort of pressure regulator that will work in the 0 to 40 lb range.
