Hitch
Matt
02-10-2004 13:39:31
Does anybody have pictures of there hitch on farmalls? I am wondering what would the best way to do a hitch on a 300 and still have room for a weight suitcase weight bracket and wheelie bars. thanks.
John
02-10-2004 20:15:13
 Re: Hitch in reply to Matt, 02-10-2004 13:39:31
third party image
Is a 300 remotely close to an H or M or did the rear end housing change? If not, this might work.
colekicker
02-10-2004 16:25:02
ChadS had a pretty good looking setup on one of his tractors. He posted the pic a while back.
TimC
02-10-2004 14:18:06
Look at 300 Rearend under Parts and Peices in the Galleries section.
Jim
02-10-2004 14:46:37
 Re: Re: Hitch in reply to TimC, 02-10-2004 14:18:06
Good idea but too dark to view.
TimC
02-10-2004 16:40:23
 Re: Re: Re: Hitch in reply to Jim, 02-10-2004 14:46:37
Slot the upper end of the metal tubing for metal slats with predrilled holes. Bolt the metal flats to the rear axle housing blots. Slide the square tubing in place. Lay the skid pads on a block of wood and the lower end should already be cut on angles and rest on the skid pad. Mock everything up like you want it. Tack weld it then jack to the front end up in the air to make sure it comes out like you want it. If its right weld it. Carpentors clamps can hold the cross peices in place (to squeeze the wheele bars together) and welding. Ornamentl (spelling?) stock adds a nice touch to the skid pads and extra weight brackets if you cant hang enough weight just in front of the rear axles.
The slots on the top bars may be centered on the tubing and the lower bars the slots for mounting the bolt plates may be to the side or visa versa to make the top and bottom bars come out vertically straight.
