M Rocker Ratios
M Puller Too
02-09-2004 12:08:23
What is the ratio of the rocker arms on a stock M Farmall? I measured and got close to 1.75 but wanted to be sure. Also, how can you tell if an 8060 head has been previously shaved? How much can safely be taken off of this head? Is there any special clearance between the valves and my domes on the pistons? Thanks very much.
farmall
02-09-2004 15:41:56
 Re: M Rocker Ratios in reply to M Puller Too, 02-09-2004 12:08:23
1.65 ratio stock. Shaving a head to increase compression is a amature way to do it. You would need to take off more than is available to help. Use the right head and piston combination to get the compression you are after. An 8060 head isn't even good for a boat anchor, it would sink the boat. Go with a 362174-R1(400-450 gas) head. Just my 3 cents worth. Hope this helps
