Help With Turning Up The Horsepower on A JD 4520
Wanting to Pull
02-08-2004 19:31:06
Recently purchased an early model 4520 John Deere, and want to Tractorpull with it. I have been pulling John Deere 2 cylinders for years, but have alot to learn about the 6 cylinder diesels. What specifically, can I do with the stock setup to make the most horsepower out of what the tractor already has. How do I turn up the pump for (what is the smoke screw?) the maximum horsepower, and are there any internal modifications that can be made to the pump to get extra horsepower. Want to use stock parts this year, then next year do some parts upgrades. Any information would be appreciated!
The Swami
02-08-2004 20:15:30
 Re: Help With Turning Up The Horsepower on A JD 45 in reply to Wanting to Pull a 4520 JD, 02-08-2004 19:31:06
First off, which pump do you have, the CBC series, or the DB pump, if you have the CBC, you will have to switch to the DB if you want to get any fuel flow.
02-10-2004 08:42:36
 Re: Re: Help With Turning Up The Horsepower on A J in reply to The Swami, 02-08-2004 20:15:30
Unfortunately I have the early model 4520 with the pump mounted on the left rear. Is it possible to do a swap to the late model 4520/4620, and if so what would be involved?
Redman
02-10-2004 18:31:45
 Re: Re: Re: Help With Turning Up The Horsepower on in reply to Wanting to Pull a 4520, 02-10-2004 08:42:36
i don't know what is involved but you can swap a 466 in there.
JDGnut
02-09-2004 07:49:53
Some of those 4520's got the 4620 engines.. Which had the injection pump mounted to the front cover... If you have the pump mounted there.. U have endless choices of injection pumps... JDGnut
ol George
02-09-2004 20:20:40
 Re: Re: Re: Help With Turning Up The Horsepower on in reply to JDGnut, 02-09-2004 07:49:53
My thoughts, I would hunt a 466 out of a 4455 or something similar. Two reasons, you get a crank driven oil pump, and you get easy cubes to start with.
