560 diesel
zig
02-07-2004 15:48:13
building 560 diesel for pulling keeping stock cui what can i do to fuel system and head to improve it and what kind of power should i expect
E J
02-08-2004 12:29:19
 Re: 560 diesel in reply to zig, 02-07-2004 15:48:13
? rpm,turbo,wt.class,antique,farm stock,hot farm what are you pulling in.I have two 560s one with a 301and one with 282 both have 370 roosa master pumps and IH midget injecters both can run 3000rpm if I want depending on what class I run also have turbos for both.16.9x38 on one 15.5x38 on the other .Pull 6500&7500#in classic class & farm pulls .90hp with out turbo to 130hpwith .FYI 806 pump bolts right on.
jason b.
02-07-2004 18:31:36
I have a 460 diesel that i am doing the same thing to. I had the head ported and polished the had new valves seats and guids in but the valves wer 30 thousands over sized and it made a big diffrence plus i ported my manifolds. Then had the injectors re done then had a new head put in the pump but not sure what it was. good luck with your prodject. hope any of this info helps.
John
02-07-2004 20:22:04
 Re: Re: 560 diesel in reply to jason b., 02-07-2004 18:31:36
We built our 660 diesel a few years ago, we had the lift increased on the cam, put in the bigger late 282 706 valves, had the head flowed ported and polished. I ported the manifolds myself. The injectors had the pressures reset, and we are running a double roller pump. We have plenty of smoke, and adjusted the fual on the dyno so that we were not drowning the engine with fuel. It will pull 4th gear high TA at 8500, on clay around here with no problems. Good luck, its a learning curve.
