Cam grind
dj
02-07-2004 03:10:40
I want to know if it is worth it to have my cam ground to pull in a stock rpms class with a super M farmall with new pistons and sleves and a 450 lp head
John
02-07-2004 20:28:06
 Re: Cam grind in reply to dj, 02-07-2004 03:10:40
I know everyone has an opinion, but I believe it helps. We have a good camgrinder who has quite a few good profiles. If degreed properly when installed I have found that in the stock classes, a good torque grind will help the tractor hold the rpm in the desired range longer. By changing the head, compression, and cfm it should benefit by changes in the lift, and or duration of the cam. Call Camcraft in Easton, MD. Talk to charles. He does quite A bit of work for the big rig pullers, and quite a few antiquers. Let me know if you can't find the number.
