14 to 1 B compresion
jdtruble
02-05-2004 07:23:41
I am putting in aluminum pistons in my 1940 B and boreing it out to 4.732 and the place on where I am getting the pistons from told me that I would have about 14 to one compresion. Has anyone done this before? if so any problems.
Big Jugs
02-06-2004 08:40:28
 Re: 14 to 1 B compresion in reply to jdtruble, 02-05-2004 07:23:41
Had an A built to 13-1 comp. for pulling and it ran like crap. Just too high on comp. Would not lug at all. Made a few changes to reduce comp. and it idled better, lugged alot more. Comp. is now around 9-1,that's where alot of pullers seem to say where to build at.
Eric
02-05-2004 17:15:19
ask them to measure from the center of the pin to the top and compare that to your old pistons. I have some doubt that it will be that high. Most replacement pistons wont get you past 8 to 1 but I could be wrong.
buickanddeere
02-05-2004 11:16:07
While increasing compression as long as detonation is prevented, does increase the engine mechanical efficiency.( power out per gallon of fuel in). There comes a point of diminishing returns where going Eg. from 11 to 1 upto 14 to 1 gains little power compared to the jump from 4 to 1 upto 7 to 1. Flame travel gets really contorted getitng from the side of the piston up to the top and over the dome.
jdtruble
02-05-2004 13:24:35
 Re: Re: 14 to 1 B compresion in reply to buickanddeere , 02-05-2004 11:16:07
Any ideas on the amount of horse power to expect?
buickanddeere
02-05-2004 13:54:42
 Re: Re: Re: 14 to 1 B compresion in reply to jdtruble, 02-05-2004 13:24:35
HP all depends on a multitude of other factors yet unstated. Anywhere from less than stock to 55HP
